im not sure you can without heating it up to soften the plastic
check by removing the radiator shroud (plastic when you open your hood, has all the HVAC and emissions specs on it) and i believe you can unscrew the lights from there
oh ok thanks! one of those black deals that goes over the bulb inside there fell off and is just sittin on the bottom so i want to atleast get out of of there. I will sure check it out, Thanks!
no problem, that happend with my headlight, i think i need a new one because it shines different than my other one, i just used the air compressor and blew the stuff out
