Transmission/Middle Console getting hot?
Hello all,
Before I go on this is what I have:
2007 Mustang GT
Manual Tranmission
89,532 Miles
Last maintenance 4,000 miles ago
Lately my stick and center "console" (where the cupholders and E-brake are) is getting hot, it's not blazing hot but hot like when you just get clothes out of a dryer. I do live in Southern California and my commute is 120 miles a day in LA traffic but it has never done this before. I also notice under my seat if I touch any metal hardware it is also very hot along with the floor? Is this a common problem or should I be concerned? Thanks for any help you can supply me with.
-Kyle
PS: This issue usually happens about 20 minutes into a drive.
2007 Mustang GT
Manual Tranmission
89,532 Miles
-Kyle
I have an automatic and occasionally when I drive I notice the same thing. Those are hot parts under the car so I would say it's perfectly normal. It's not like it's getting hot to the point of damaging anything.
I am hoping it is just the recent heatwave or for all I know I never noticed it and its always been like this. I am concerned also because I am not the most car savvy person ever and I find it hard to shift into gears at times. I just assume its an American car and thats why its tough to shift (Sometimes I need to go to Gear 3 and then 1 to put it in gear because im afraid I can like snap the gear stick or something).. But another side of me is paranoid that my car is broken.
Hello all,
2007 Mustang GT
Manual Tranmission
89,532 Miles
-Kyle
2007 Mustang GT
Manual Tranmission
89,532 Miles
-Kyle
I have an 07 GT and I notice the same thing but I believe it's perfectly normal. If it bothers you you could pull up the carpet/console and put Dynamat/heatshield stuff down to lessen the heat. If you look under there now you'll notice there is really nothing there to prevent the heat from soaking into the cabin.
Yeah when I did my sound deadening I pulled EVERYTHING out of the car and I was amazed that like 98% of the car has no type of insulation or dampener! There's about 1/2 of 2ply sheet metal between you and the trans so any heat at all will soak through. I put down dynamat and some heat/sound foam stuff and the car stays sooo much cooler in the 115• Texas heat! Pluss it's quieter. Doooo it, dooo it
I changed the tranny fluid to RP syncromax and noticed a difference in temps. No kidding. I don't buy into most manufacturers claims about wonderfluids but my shifter shaft was getting pretty warm after a long drive and I decided it couldn't hurt. It helped.
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
