No Arm flash on alarm & double honk...WTF?
09-09-2009, 10:06 AM
Stock Alarm was fine until last week. Now no lights when arming with remote.
Then a double honk if you push it twice.
Any ideas??
09-09-2009, 10:32 AM
Usually the 2x honk means your trunk isn't latched.
09-09-2009, 10:38 AM
run a system test and it will show you if all your doors and trunk are shut...
09-09-2009, 04:23 PM
Cut & Paste Expert
09-09-2009, 04:27 PM
Gentleman's Relish
Double honk means a door or the trunk is not closed. If the door/trunk switch is bad (loose or bent) that could also cause it.
Do the lights in the passenger compartment shut off after you shut the doors?
Does the trunk light stay off when you close the trunk?
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
guitarman376
10-11-2015 01:47 AM
UrS4
10-03-2015 06:23 AM
UrS4
09-30-2015 10:13 AM
JoshyGT
09-07-2015 02:04 PM
