anyone with roush rear springs only
But not the Roush Rear springs and matching shocks.
Yes its more harsh but it handles like a go-cart and
the wheel hoppage is G O N E.
Put poly bushings on your panhard bar and sway bar
for the full effect.
Its 100% better handling. WTF was Ford thinking,
no rear sway and all these rubber control arm bushings....
If you leave the OEM shocks, they will toast out faster from
the Roush springs? Best to get the matching shocks as well.
ps the springs go in with the word ROUSH rightside up
Just saw the 'i dont want improved handling, just a rear body drop'.
Stick some Roush Rears in there but the ride will suffer.
You will feel EVERY bump. I want that, but you seem to not...
A week after installing the springs I wanted to take them off due to the harshness or more specifically the unequalness. Concrete roads were unbearable, but back curvy roads were awesome. The rear end lost its tendency to roll over in corners, but added a tendency of 'rocking horse' front to rear. The spring rates in the front and rear are now different, so they both handle bumps differently, the front is mellow the rear bangs. If you don't want to lower all four corners, that's just how it's going to be.
Maybe I should just come right out and explain what I'd like to do. Is it possible to make my rear end lower WITHOUT making the ride more harsh. I don't drive my car hard its all about the look for me. Especially, because it's my daily driver. I want that lower rear end look but I want the ride as soft as possible even if that means going softer with shocks or whatever. Mustang looks with a Cadillac ride.
I put the eibach pro kit on my car with stock shocks. Fairly rough but I like the car to not be mushy. It doesn't bounce at all over bumps, just bumps and its done. If I had to do it over again I would do it exactly the same way. I put them on expecting the stock shocks not to work very long but they have still been going strong. I think I have 46k on the car and about 25k of that with the springs. Older people dont like the car to be a rough ride but I love the way the car handles now.
I was looking at doing the Roush setup but then I saw pics with the car looking more even with the front. I want it the same way is now, higher in back with no gap in back. This has lead me to buy some Steeda Ultralites for all 4 corners. Make the drop even all around and eliminate wheel gap. Perfect.
I believe there is a company that offers springs in a kit, front and rear that drops the front .8 inches, and the reach 1.3 inches, leveling it out. Can't remember the name tho... aybe H&R or Vogt-something or other...
