2005-06 whipple to fit 2007?
what needs to be bought to make an 2005-06 whipple to fit a 2007? is there any major changes? what about the computer programming diferences or would it be better to have it dyno tuned?
The only real difference is the coolant crossover between the cylinder heads, and the thermostat housing. I don't think the computer changed between the two.
As to whether or not it will fit, I'm not SURE... but I don't THINK so. Maybe someone with more knowledge can chime in.
And a dyno tune is ALWAYS better than a mail order. ALWAYS.
it will work just fine for the major mechanicals.
the PCM strategies are going to be unuseable. you will need Dyno tuning just to start the car.
so depending on the price, it may very well be worth it. it will just involve some research via those installation instructions
go to Whipple's site and download both of their installation instructions. then go through and compare them.
you may have to do some "downgrading" to convert back to a 05/06 setup
you just have to get the different pieces as described above.you may have to do some "downgrading" to convert back to a 05/06 setup
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
