those dang Rattles!
those dang Rattles!
I have a rattle noise that happens pretty often, it is coming from the passenger airbag dash area. I know this because when I have the passenger press on the dash it stops rattling... Anyone experience this? If so, whats the fix??
I know simple things like putting the windows down, or turning up the radio = fix, however I usually drive with the radio off to hear the car purr
Any suggestions are welcome!
Thanks!
Thanks!
TSB
FORD: 2005-2009 Mustang
ISSUE:
Some 2005-2009 Mustang vehicles may exhibit a rattle noise where the A-pillar meets the dash area. This rattle may be due to worn, missing or off location tape under the dash panel and/or A-pillar dual lock (velcro) fastener(s) not seated.
TSB 08-24-10
ISSUE:
TSB 08-24-10
i am right there with you
i have the one you were talking about
one on the drivers side
and the most annoying noise coming from the rear passenger side seat and it squeeks its so annoying and i cant find it
I have a rattle occaisionally under the car when I am cruising and put the car under a slight load. I saw the thread about the piece in between the engine and transmission, but I thought that was for a car with a manual tranny, mine's an automatic. I have looked at the heat shields and the look fine, not out of shape or touching anything. Any ideas? 2007 and only 8000 miles on car.
There is a plastic insert behind the inner door latch lever that I found rattles a great deal. I used double-sided tape behind both of them, which work perfectly. Be advised, though, that if you ever need to take apart the door panel (ie: replacing speakers), it will make it a bit harder to pop that panel off. It's possible, just a bit trickier.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
movielover40
09-15-2015 10:37 AM
