Sponsored by:
Sponsored by:
My brake reservoir is coverd in dirt.. why?
Old 10-09-2009, 09:13 AM
Fort LiquordaleGT
Fort LiquordaleGT's Avatar
Default My brake reservoir is coverd in dirt.. why?
I was changing my cabin air filter and I noticed my brake fluid reservoir is covered in dirt.... Anyone else have this problem?
Fort LiquordaleGT is offline
Old 10-09-2009, 09:17 AM
whyask
whyask's Avatar
i think thats pretty much every car, mine has always been like that every car ive owned !
whyask is offline
Old 10-09-2009, 09:22 AM
NJ3
NJ3's Avatar
The cap for the brake fluid reservoir on our cars tend to leak a little. The fluid will collect dirt, the bigger issue is if you look below the reservoir you will probably notice paint bubbling on the firewall and frame from the fluid.
NJ3 is offline
Old 10-09-2009, 09:26 AM
4LITER6
4LITER6's Avatar
Teflon tape works....
4LITER6 is offline
Old 10-09-2009, 09:35 AM
Doogie65
Doogie65's Avatar
Just stumbled on these threads a couple days ago that have a quick and easy fix for this problem. You simply add a neoprene washer under the stock rubber seal in the cap and problem solved!
http://forums.themustangsource.com/s...brake+cap+leak
http://www.teamshelby.com/forums/ind...brake+cap+leak
Doogie65 is offline
Old 10-09-2009, 01:27 PM
Fort LiquordaleGT
big thanks I just bought that washer from one of those links lets see if it works.
Old 10-09-2009, 01:48 PM
Starfire
Starfire's Avatar
I did the free version. I cut a piece of thick plastic (It was a container, oil bottle? don't remember) in a circle and placed it under the rubber seal in the cap and presto, no more leak.
Starfire is offline
Old 10-10-2009, 05:24 PM
157dB
Cut & Paste Expert
157dB's Avatar
Its leaking and attracting dirt.
Your next post in the future will be something like
"the paint is peeling around my brake reservoir"...
157dB is offline
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: My brake reservoir is coverd in dirt.. why?
