GT/CS Rear bumper Question
Anyone with this bumper notice it being kinda loose? The three tabs along the bottom of the bumper dont seemed to be very secure and it allows the section below the license plate to move back and forth a decent amount. Im just wondering if it moves while im driving too. Does anyone else have a slightly loose wobbly bumper or should it be pretty solid?
The only "loose" section that I have noticed is the black valance, I think because of it being the cheap plastic. i only notice it when I am washing the car and actually move it around myself. Otherwise, my bumper is solid.
That pretty much what i mean, I noticed the three bracket things that hold it to the bumper in the area seem to be loosely riveted on which allows the valence area to flex alot.
Well, I have had my CS for 3 years and never had an issue with the valance. I wouldn't worry about it too much if I were you. I have always lived by the saying....."If it ain't broke, don't fix it."
i think i ended up using some aircraft tape from my dad. Teflon based stuff and i just kinda wrapped it around the pin or the whole. I dont really remember what i did but i know all i used was some tape to wedge into the right spot and its a bit more snug
It would become a problem only at high speed, because the air pressure trying to push it outward (in that case backward lol).
A customer of mine in Belgium had all 3 of his lower tabs broken on his GT500 and I noticed his bumper being really loose following him in another fast car.
We were only doing 140+ mph, lol. (was fun that day).
If it wasn't for someone seeing it from behind, we would never know and eventually the bumper would have ripped itself off at the bottom.
The way we fixed it was to make an aluminum shield all the way across between the exhaust tips.
We riveted that shield at the very bottom part of the bumper and screwed it to the body of the car where the middle broken tab would normally secure into.
You couldn't see the rivets until you had your head right underneath the bumper...
That shield kept any air turbulence from happening since there was no more factory opening.
The easier way, would be to make aluminum tabs (with 2 rivets each) just like factory had them, so you can reuse the same location points and push on clips.
That would be good enough of a repair, since we're not driving 140+mph that often in the US now, are we?
