I did it with the hood on. Place a blanket or towel over your engine just in case you get some shavings. Most of mine were on the hood, I used a vacume and dabbed them up. The template was good, make sure the scoop is centered on the hood. Good luck and post pictures!
I didn't even drill it. I just used the 3M prep stuff and stuck it to the hood. Hasn't budged. This is how many body panels pieces are attached too. No issues... Granted I mounted mine in reverse so its slightly more aerodynamic, but I don't believe for a minute that having it "scooping" when positioned forward will make it break off and fly away. Its closed off. That thing is stuck on there like crazy.
How bout some more detailed hi-res pics of this Roush
Scoop mounted backwards.
Did it fit inbetween the WW squirters.
Intrigued here....
