Added Hood Scoop - Should I Stripe It Or Not?
#21
I had the hood scoop added last week. Car has sat in the garage till this morning, when i got to work I noticed that the scoop was raising off the hood. The tape is not holding. Called the dealer they put it on. Waiting for them to get back to me. Has anyone else had this problem? If so what did you do to fix it?
#22
#26
That's the thing. Immediately after install it will look fine because the tape will hold for a while. But, after time it will start to pull on the edges because of the tension in the middle. The middle is fine because it's bolted down.
#27
#28
With stripes: It will blend the scoop into the lines of the vehicle, making the scoop contrast less with the rest of car.
Without stripes: Accents the scoop, gives an air of distinction to the stripes that emerge from the scoop and cover the rest of the hood. And a bit more unique of a look.
My preference would be to not stripe the scoop with your particular vehicle. This is where the "Sometimes less is more" theme comes to mind.
$0.02, FWIW.
$0.02, FWIW.
#29
$0.02, FWIW.
$0.02, FWIW.
#30
And of course, if you don't stripe it now -- you can always do it later if you change your mind.
Not being in the know w/regards to stripes, I don't know the reversibility of such a modification.
I suppose it depends on what type & how they were applied.
