Hurst Short Throw Installed - Me Like
I bought a used Competiion Hurst Shifter from ZeroInGold. Got it Monday and have been looking for a new set of Poly bushings...and no luck. Go figure. I live on an Island. Guess I need to order some for the next time I go under the car.
So said screw it this afternoon, and started the install.
3 Hours later, it is in and I love it. But it wasn't that easy of an install...as anyone with a later 2008 or a 2009 model can attest to.
Pro:
1. Throw reduction
Con:
1. ZeroInGold said it had the dreaded rattle.
So I am a happy camper. The Hurst is an entry level short throw shifter...and you get an excellent product for the price. And I can't complain as I got a super screamin deal for mine used.
The drive tunnel has a heat/noise matte installed that interferes with the bolt lining up and caused me easily 1 hour of my life to be wasted.
This truly is a super easy install. Except for that damn front bolt.
Pro:
1. Throw reduction
They are not kidding. At least 40% is advertised. I am no longer rowing a boat.
2. Shifter PlacementI'm 6'3" @ 280lbs.
With the stock shifter my arm was sitting a bit more forward than comfortable. Now it's about 1" farther back, and my arm is in a more natural position while resting.
The shifter also sits higher. Again, more ergonomically correct for me
3. Gear EngagementWith the stock shifter my arm was sitting a bit more forward than comfortable. Now it's about 1" farther back, and my arm is in a more natural position while resting.
There is absolutely no confusion about being in gear. There is an audible and physical "click" when you shift into/out of gear.
I like it. With my OEM shifter I had ground 3rd gear a few times thinking I was in gear, but was only part-way there. Not an issue anymore
4. LooksI like it. With my OEM shifter I had ground 3rd gear a few times thinking I was in gear, but was only part-way there. Not an issue anymore
Only a motorhead would really notice anything is different. I left the leather boot alone, and the Hurst ball is the only indication anything is "weird". The White is a nice contrast with my black leather & black dash
Con:
Didn't experience it tonight during my testdrive luckily. But I drive with my hand on the shifter...so I doubt I'll ever see it actually
If it appears, I already have that Gun oil in my Gun Cabinet
2. Handle/Ball placementIf it appears, I already have that Gun oil in my Gun Cabinet
the shifter now sits at least 1" farther back, and 1.5" taller than the stock shifter.
I typically change the radio channel with hand on the shifter and mid finger...but now cannot. I know, it's stupid...but I'm a creature of habit. have to retrain myself.
btw, that 3 hour install was only really about 2 hours
I have the Track Pack...so no jack. And the car is too low for my Bottle Jack to fit.
Luckily I remembered my Expedition has a Scissor Jack. That whole process took roughly 1 hour just to get some jackstands under there...bleh
I think everybody should get Hurst short throw shifter or at least somewhat short throw shifter because you know what gear you're in after you shift and it's a lot more fun to drive with it!
Glad to hear it worked out well for you man.
Ps. Even though I don't race, but I can tell it definitely helps you out.
for the money...$180 shipped is an awesome deal for what you get. Sure it ain't as fancy as the Tri-Ax, MGW or some others...but the results are amazing.
I might later upgrade to the Pro 5 for the 3rd gear assist. But for now, I can't argue with $80
Guess I'll find out how hard that bolt is because I just orderd the billet comp, should be here today.
How much room do you figure I'll need under the car? I made some ramps that will get it about 3-4" higher. And what do you mean "Track Pack...so no jack.
I think he means the Bullitt sits a little lower than a standard Gt. I don't think its sits much lower, just a little bit.
