Diff housing, axle tubes, and brackets not painted. Why?
#21
POR 15 is what I've been using for years and it's on my car.
Best product out there, it comes black or gray.
Lightly wire brush the rusty stuff, and brush it on with a regular paint brush.
The metal doesn't have to be really clean, that's what's great about it...
Apply it on surface rust, use about 2 coats and you're done.
Two advices though:
1- Don't put any on your skin, it's a real pain to get off.
2- This product has a short shelf life once open.
If possible, keep it in a container small enough to trap the minimum air inside.
In other words, make sure said container is full.
http://www.por15.com/
#22
Not a stupid question...
Two advices though:
Two advices though:
Thanks for the great info.
#23
I agree. I know this isnt some $100k + super car, but I'd like to keep it for a while, and possibly pass it down to my son in a decade or so. I'd rather it not look like farmer Joe's 1972 Dodge truck when I do it.
#24
This is the first car that I have purchased that has bare metal areas under it. The Japanese cars all have an undercoating and my Ram is fully painted underneath including the differential and drive shaft. Go figure
#25
There are several reasons why car manufacturers DON'T paint areas under the car. As nuke pointed out, the surface rust protects the underlying metal. Since 95% oft he people don't care about what they can't see the OEm won't paint the part because most people won't maintain it.
However, this also has a secondary purpose. In areas where road salt is used or other chemicals can/will get onto the underside of the car, when not removed they EAT paint. The bubbles of paint actually TRAP water and other contaminants under them thus accelerating the corrisoin you wanted to avoid by painting the part in the first place.
Point is...if you plan on painting it you better plan on maintaining it just like the body of the car (wash, wax, clean etc) otherwise you're worse off than where you started.
If you are that concerned with the underside of the car, paint it and maintain it, or undercoat it. Both require additional work after they're done.
#26
#28
Aw man, I HATE YOU!!! Now you make me want to clean mine up. Shoot, like I don't have enough work to do.
Looks nice dude. Better than that rusty orange look I have going. Did you wire brush or just spray over the rust?
#29
I didn't wire brush it that would be a lot of work. It was hard enough painting the the pumpkin. I'll get more detailed with it when I put a new suspension kit on it(roush stage 3). I figured it would be better to do it now since its new then it would be later when everything is dirty.
#30
Back in 2007 Ford at least painted the pumpkin, but left the axle tubes and suspension brackets bare metal which would corrode. I removed the rust and applied primer and paint. Two years later, it still looks pretty good.
daltron
04-28-2016 08:10 PM
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
