Center Force Clutch noise
Hey all, I have a question regarding our 2006 S197. It's a GT 4.6 Saleen S/C with a Tremec TKO600 Manual Swap from an auto. that was a TON of work, and continue to work out little bugs. First something happened with the RAM clutches slave cylinder in which it blew a seal out and I lost clutch pedal. but I got that fixed and now everything seems pretty good. My only issue is the Centerforce clutch (with the centrifugal weights) makes alot of noise whenver the clutch is not pressed in. It doesnt sound like a throwout bearing or anything like that, it sounds best I can describe it online is crickets, it's like metal on metal squeeking. I've removed the inspection cover on the bellhousing and sprayed the weight blocks with a little bit of viscotene (very tiny amount so it doesnt come in contact with the clutch material) and the noise went away for about 30 secs. then it came right back. Has anyone else ever experienced any noise from their weight blocks? and if so what can I do to fix it? if anything? This is not my car it is my father-in-laws, but I've done most of the work to get it to the point where it's at now. With the Manual Trans swap it dyno'd at 434HP and 510ft-lb torque. Fairly impressive in my books. If you need to know more about the car, let me know and I can provide that info.
Thanks in Advance.
Thanks in Advance.
I had a centerforce installed in my V6 and right off the bat i notice it making noise. Mine is a rattling sound thou. I took it back in to the ford dealer that installed it and they said it was normal Gear rollover. Sound only happens when the clutch is out and and i am sitting in neutral. If i give it just a little gas sound will go away or i can press the stick up against one of the gear "gates" not press hard but just a little pressure. Not sure if ford was blowin smoke but the clutch has been installed for 20,000miles with out a issue.
I do hate sitting at a light with that thing rattling thou, sometimes i will hold the clutch in if i am trying to look cool if there is a car next to me i know they can hear that rattling and are wondering What the Hell is with my car.
the noise really wouldn't concern me except, it only started after the slave blew the seal, before that the first time we installed the clutch and conversion, there were no noises, it was quiet, and perfect, then blew the seal barely made it home, R&R'd the trans sent the slave off to be rebuilt, and then put it all back together and now I have this screeching sound. It's really annoying to me, my father-in-law who owns it and primarily drives it, can't hear it, but I can hear it over my Cummins diesel that was idleing right next to it.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
KingRando
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
