normal compression numbers?? (05-09 GT)
I found this link on a BMW forum discussing the money shift: http://www.shortshifter.com/techniques2.htm
Actually it does matter on the compression ratio because the amount of cylinder pressure is directly related to the compression ratio using the following equation:
P2 = P1 * (rc)^k
P2 is cylinder pressure after the compression stroke
P1 is the intake pressure
rc is the compression ratio
k is assumed to be between 1.35 and 1.4 for the polytropic process
P2 = P1 * (rc)^k
P2 = P1 * (rc)^k
P2 = P1 * (rc)^k
While this is true, the original compression ration of the given engine will not be indicative of the damage potentially done. By the time one figures out the new compression ration, you've already taken readings on the cylinder pressure, thus the information the OP was after, would have already been figured out.
breaking
10-02-2015 01:27 PM
