CDC Shaker and CAI...
I may be purchasing a CDC shaker in th near future, I've always liked them and would rather invest my money into this instead of window louvers and side scoops. I currently have a JLT CAI, will I still be able to use this with the shaker unit? Feedback appreciated, thanks!
Yes you can & it's a great combo.
You'll need to cut a hole into the JLT filter shroud to route the air tube into, similar to what you'ld do with the stock airbox.
A few pics of my install, before & after I trimmed my shroud down.
I also used a different air tube on mine, as I didn't like the supplied plastic piece, it had too many restrictions.
I've had my Shaker on my '05 GT for more than 2 years, I already had a CAI (K&N) when I did my install. It will take some basic fabrication to make it work properly together. All that is usually needed is to modify the air box and find an effecient way of passing the cold air into the air box/heat shield. There is a guy in my Mustang Club that has the JLT with a Shaker, and I am changing to JLT over the winter.
JoshyGT
09-19-2017 08:52 PM
Shifty Magoo
08-25-2015 03:08 PM
