Top Speed?
#31
In the case of the OP, the calcs would be correct. Drag will limit your ability to reach redline in top gear if you do not have enough HP to overcome the drag.
However in the OP he made it to redline, this means that he had enough HP to overcome the drag. So at redline, given the gears, he would have been going 174mph. Drag is not part of the equation here because mechanically, unless he was slipping, the car was turning the RPM's with the gears and tire size to be going 174mph.
Damn fast!
Damn fast!
#32
******CORRECTION*******
I didn't change one of the variables in the earlier analysis. So I re-ran it (it's a spreadsheet solution that only takes a few seconds)
173 mph at 6150 rpm. Slightly past the 6000 rpm indicated redline, but still drag-limited assuming that the torque curve stretches out smoothly but dropping slightly to a 6250 rpm redline/fuel cut.
(trap speed went up a tiny bit to 119 mph)
Norm
mungodrums
09-29-2015 09:18 PM
musnicki
09-23-2015 07:11 AM
