Also, if at approximately WOT for three seconds or more, the alternator goes into default mode of 13.5 volts. The alternator remains in default mode until the ignition is turned off.
No wonder !
I have a volt meter and it rarely reads 14.0 +Volts
I always chalked it up to heat soak leading to lower voltage but now i know
so i guess a simple restart will have the alternator back up to 14+ volts?
As I mentioned at post #7, my first post wasn't good. Something can happen with the alternator voltage at WOT, but I don't know if it only occurs when there is a problem.
I'll take some readings tomorrow and post the results.
Can't really duplicate a 'problem' scenario, but will post baseline & WOT results, FWIW.
