Storin' it - Need some info.
I'm located in the midwest area. Snow and ice are pretty much around the corner and I'm putting the 'Stang away for a few months. I'd like to disable the vehicle so it can not be started/driven.
I'm curious to know if the vehicle has, per se, an injector fuse. This is the extent of disablement I need. Engine cranks, no fuel would be fine.
I don't want to do anything extensive nor any type of permanent modification.
Is this injector fuse idea feasible? If so, where is the fuse?
If not, any other ideas?
Thanks...
Thanks...
Lot's of threads on this except I'm not sure about disabling except for lifting the battery cable.
I'm in the Chicago NW burbs and put the Stang away last weekend and it'll be for about 4-5 months. Here are my "should do's" for anything less than 4-5 months:
- Fresh oil/filter change. A few hundred miles on fresh oil is ok providing the last run gets everything good and hot (at least 20-30 miles)
- Sta-bil in the tank (~6.5-7 ounces to treat 16 gallons), then fill-up and drive at least 10-20 miles to get the treated fuel thru the system
- Battery tender IF you still have the Motorcrap battery. Otherwise this can go on the "Optional" list
- Steel wool in the exhaust tips and any opening(s) in the intake (keeps critteres out)
- Car cover
- dryer sheet(s) in the cab
- Carpet or plastic or cardboard under each tire
- Inflate tires to ~40 PSI
The best way is to use the PATS key as the security you desire
from unintentional start-ups while stored.
Hide the key(s) and no one including you will be able to start the stang.
Except maybe a dealership...
But they could also replace the removed fuse or relay also...
You could always pull the Fuel Pump Relay from inside the BEC under the hood...
The fuse you desire is in the BEC by the FPR.
The # is located in the owners manual btw...
A couple of boxes of baking soda will absorb any unwanted odors and moisture.
If you do disconnect the battery, be sure its the negative cable and be aware
that the short drop windows will not work and the PCM will require retraining
of the adaptive learning upon unstoring of the stang.
- Car cover
No need to start the car if you ran the car for a bit (driving is preferred) to get fuel stabil in the fuel lines up to the injectors. Done.....
I have done this for many yrs and most recently the last 3 for the stang in the sig.....no problems and no worries
IMO dont waste time on putting the car on jack stands....JMO
Same opinion here. The issue with the tires is typically 2fold:
- Flat spotting - tires won't flat spot if they're not touching the ground. But flat spots occur on most tires anyway, even after 1 day sitting and the cooler the worse it is. But flat spots are just a nuisance and will go away as the tire warms up from driving. Pumping the tire up to ~40 PSI will lessen the flat spotting somewhat but not prevent it.
- Tire rot - any rubber in contact with a surface in which moisture can readily flow back and forth will cause tire rot except this is only a real issue for long term storage AND/OR if you drive your car so infrequently that you replace tires due to age and not mileage. Placing some type of media as I suggested earlier will decrease this interaction but again, it's unnecessary if you replace your tires within a normal frequency. It often takes many, many years for a tire to rot. Sitting on concrete speeds the process up somewhat.
I have a few sets of tires/rims in storage and they are aired down as
recommended by the manufacturer for storage on rims.
Out of the UV light is best.
F41 for the fuel pump and the injectors.
F40 for the ignition circuit.
Both located in the BEC under the hood.
