Mustang + Snow = Zero Traction
#21
If it had a handbrake or a footbrake that you can easily modulate, a little touch of rear brake only using it instead of the service brake will get the tail to rotate. Rather nicely, once you've had a little practice at it.
Note that this technique also works with RWD.
(SE Massachusetts and South Jersey experience)
Norm
Norm
#22
My used 17" Silver Bullets arrived yesterday and I am going to be putting a set of these on them:
http://www.tirerack.com/tires/tires....ar=Convertible
#24
+1 winter unit. I put the vert in the garage and drive a Subaru.
#25
RE: chains
It's in the manual. They are approved for use on the car, but only on the 16" tires (2008 Owner's Manual). Aluminum wheels may be damaged by them, and there is specific warning against using them with either the 17" or 18" tires. There's a few other things mentioned.
Norm
Norm
#26
