whats a 75 shot feel like??
I have an '07 5 speed, 3.73 gears, I plan on adding a tune and intake and maybe a driveshaft.
I was wondering does the 75 shot feel like a real kick in the pants??
how much time does it take off the 1/4 mile.
how many shots will the regular bottle put out??
how much is filling it cost.
would it be possible to mount an extra valve within reach of the passenger seat, so the main bottle valve could be left on while driving and if needed the other valve could be opened while driving.
it is not like you see on TV... it just sets you back a little and you can watch your rpm and speed increase faster if that makes since... I think i was knocking off almost a sec off my time, i dont know how to tell you how many shots you will get because it all depends on how you use it. it is around 35-40 bucks to fill it back up.
I had the 75 shot on my V6 and it was a "kick in the pants" when it hit! I had it set to open at 2400 rpm and before the 60' mark it would kick in. A friend took a video and the car launched, front lifted and before the 60' the nitrous kicked in and the front lifted again.
With just a tune and CAI I was running low 14's with an occassional dip to the high 13's. With the 75 shot I hit a 13.60. So it was almost a full second on my car.
I could run about 8 passes before bottle pressure became a problem (you want to run at least 900 on the gauge). A bottle heater helped to keep it up for a few more passes.
Running your nitrous lines inside the car is not a good idea. If the valve leaks your cabin will start to fill with gas. If you really want to be able to turn it on while driving the street (not really a good idea, it is really a track mod) get a remote bottle opener which opens the bottle in the trunk electrically.
As far as cost - depends upon your area. I paid anywhere from $3.75 to $4.75 a pound.
It was tons of funs. The cost caries depending on where you live and what you use. I could usually count on $40 bucks for a fill up. I think I paid $5.00+ most of the time.
Matt's 95 Stang
10-05-2015 07:16 AM
