pro kit + black wheels
Just remember with sportlines it can actually damage your handling because your suspension geometry will be off. So you will probably need a bump steer kit, adjustable panhard bar and camber bolts/plates. Most people suggest going no more than 1.5in drop overall because of the problems you can run into. Although sportlines do look great they are mostly for show.
Pro-kits, black 18's
Here's mine with that set-up. Having said that I just changed out the pro-kits to Steeda sport springs - not quite as much drop as the pro-kits - about one inch. Also had Koni STR.T shocks put on at same time. Overall I like the new set-up better than the pro-kits with OEM shocks - still very stable but ride is not as harsh.
ya so far im okay just need to change my pinion angle on my rear end just that little bit extra lowering i think altered my angle cause at high speeds it rumbles from the driveline rear end area, but handling wise its just fine so far, pretty much just working on getting some eibach shock n strut or tokicos havent decided yet but ill post up pics soon
Im liking the pics so far. I really like chrismakk's car, but I cant decide if I want the all black, or the deep dish black with the chrome lip. Also, is anyone with a prokit having any problems with the rest of their suspension? I am not wanting to replace anything else, or caster/camber bolts/plates. Finally, what size tires is everyone going with who has the 18x10/18x9 staggered setup? Thanks for the help!
