for those wanting 4.10s
make sure you don't street race often, they will disappoint you in the long run... My 4th shuts off at around 120, and then you loose the race, seems like I should have got 3.73s as the 4.10s seem to be more track friendly... Acceleration is good but doesn't help against lsx cars..
Here's the top speeds for the manual @ 6500 RPM:
w/ 4:10 -
1: 38
2: 64
3: 97
4: 128
5: 191
R: 37
w/ 3.73 -
1: 42
2: 70
3: 106
4: 140
5: 210
R: 41
Calculated here: http://www.catherineandken.co.uk/sti/tyres.html
Using: 3.340:1 first gear ratio, 2.000:1 second gear ratio, 1.320:1 third gear ratio, 1.000:1 fourth gear ratio, 0.670:1 fifth gear ratio and 3.380:1 reverse gear ratio Tremec 3650
Of course, you may actually get a little less due to drag. I know those speeds at 5th will not happen.
w/ 4:10 -
1: 38
2: 64
3: 97
4: 128
5: 191
R: 37
w/ 3.73 -
1: 42
2: 70
3: 106
4: 140
5: 210
R: 41
