Last edit by: IB Advertising
Browse all: Ford Mustang Specifications & General Maintenance
- Ford Mustang V6 and Ford Mustang GT 2005-2014: How to Jack Up Your Car
Step by step instructions for do-it-yourself repairs.
Best place to jack up the front??
Installing my shorties tomorrow and im wondering the best method of lifting it and not having to worry about it. Normally i just jack up one side at the cutout right behind the tire on the side skirt and then slide a jackstand closeby just incase the jack fails.
So, how do you guys normally lift the car for an extended period of work?
i agree with the ramp approach
and... whats the k member look like?
The k member (if you have one) is the support from the drivers side suspension directly over to the passenger side. Mine is inches away from the drain plug for the oil pan.
Take my advice, if your gonna be under the car for any extended length of time (like installing headers), then it makes it much easier if the jack stands are as far out of the way as possible leaving enough room to move around under the car. Header installs are never fun, and you dont want the jack stand right in the way when you need to reach all the way up to unbolt the manifolds.
Good luck.
Good luck.
