Hesitation/Loss of Power While In Boost At WOT
#24
It goes into boost then I hear a large surge of air and lose most power.
But, when my car is at a stand still and I accelerate with a partial throttle there isn't much power there either making it difficult to merge with traffic.
I don't know if it's normal but there is something protruding from where the Whipple blower assembly meets up with the manifold area. It looks like a gasket.
I'll post pics.
#26
DING! DING! DING!
Build a boost tester (it's easy) and pressurize the system, look for leaks. Also when DID this problem start?
You can get the idea for a basic boost tester build at a site like this http://www.vfaq.com/index-main.html
#27
#28
I would contact someone who deals Whipple products or even Whipple directly with a picture. It should be really easy. I takes about 10 minutes to pull the blower off my car so I am assuming your's is similar.
Try googling it.
I wonder why it did that in the first place. Did you have any strange things happen like a backfire or bounce off the rev limiter a bunch?
#30
Yes, I have an Autometer boost gauge.
I'll post pics.
I'll post pics.
Whipple will sell you a new gasket. This one may be salvageable. Pull the blower (you will have to no matter what) and see if the gasket is torn. If it isn't get some gasket maker, gasket cinch, or high temp rtv and use it to hold the gasket on the manifold. Then put the blower back on. Good luck.
