MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   2005-2014 Mustangs (https://mustangforums.com/forum/2005-2014-mustangs-43/)
-   -   Help! Dash power outlet doesn't work! (https://mustangforums.com/forum/2005-2014-mustangs/579307-help-dash-power-outlet-doesnt-work.html)
jtpowers72 Dec 29, 2009 10:25 PM
I just got a 2008 Ford mustang today and absolutely love it; however, I found one problem that is driving me crazy!! The power outlet on the dash doesn't work; therefore, I cannot plug up my gps. The power outlet in the armrest works perfectly. My first impression would be a fuse, but I don't know which one it could be. Anybody know what the problem could be, or where I should start?
loudnlow Dec 29, 2009 10:56 PM
Check your owners manual which fuse it is. My next guess would be check if its plugged in behind the power outlet.
partsbill Dec 30, 2009 05:56 AM
located in the power distribution box under the hood check the following:
fuse# F61 cigar lighter 20 amp
fuse# F64 power point 20 amp
Nuke Dec 30, 2009 06:32 AM
Your car IS under warranty, right?
jtpowers72 Dec 30, 2009 08:29 AM
Thank you
It was fuse number 61. Thanks so much
StickShifty Dec 30, 2009 10:30 AM
easy fix!!!
retro_pony Dec 30, 2009 08:12 PM
I had the same problem when I got mine. Turned out to be the fuse as well! Good fix.
157dB Dec 31, 2009 11:37 AM
Help yourself and get the owners manual
and check the fuse.
Does your mom hold your hand while you pee as well?
Owners Manual Online
Nuke Dec 31, 2009 12:29 PM
Originally Posted by 157db (Post 6722380)
...Does your mom hold your hand while you pee as well?
Whack... Be nice... er.
hammeron Dec 31, 2009 01:11 PM
welcome back db, good to see ya
© 2026 MH Sub I, LLC dba Internet Brands
