HOTRODs IN!! W/before and after vid link!
#22
Sweeeeeeet. So are you happy with your Brenspeed tune? Notice a power increase with the cams? I did. I'm smokin tires so long in second I have to let up on the throttle Mine runs awesome on their 91 octane tune.
#23
Location: from Warwick, RI but live in Ft Walton beach, FL
Tunes seems fine so far but I haven't had much play time with it. I still plan on a dyno tune which I hope will be this Monday once the shop here can get the software update from SCT
#24
I've reduced it to 6500rpm now with the stock drivetrain.
#27
mine is set to 900. if I went lower the rolling stop idle would bounce alot. I can't tell a big difference in my current vs when I had 700rpm as my idle.
#29
timmbo, i don't think it's the transmission....i
think it's the throw out bearing on the slave
cylinder rattling against the pressure plate
fingers.
a number of folks have this noise and it's worse
if you have torque limiters.....that's why i took
mine off. i'm idling at 750 and the noise is
really quite minimal and doesn't bother me much.
if we are both talking about the same noise, it
goes away when you press the clutch pedal.
fingers.
