i have a"fuel pump" sound that gets louder with speed noise
well over the few month ive notice a high pitch noise coming from under the back seats while driving. First thought was the fuel pump and thought nothing of it until i notice that i would get higher with speed or lower with deceleration. I checked under the car at the u joints and any rotating wear items everything felt solid and lubricated.
Any ideas?
The only mods are in my sig
Any ideas?
I didnt think of the speakers, I have the shaker 500. In a previous car i had the alt noise your talking about. This noise im having doesnt sound like that but when i listen for it you can only really hear it with the radio off. Ill pull the fuse for the radio to eliminate speaker noise though.
I had my clutch packs replaced about 10K ago my car was at about 15K when i had them done under the TSB. I could duble check and check the level of the rear
You'll get the speaker sounds with the radio on or off.
Does it make the sound when you are stopped? If so, then you know it's not the rear end of pinion bearing as suggested.
Also I wouldn't worry about my rear end fluid level unless I had a noticeable leak. It's not like oil and burns away.
ok, well i ruled out the motor and the speakers. I found a big hill and pulled the radio fuse and left the car in neutral and rolled down the hill. At about 25 mph i stared to hear a very clear noise coming from the back of the car. Very faint but still there. the faster i go the louder it got but again almost un-noticable but i hear it. It then goes away around 25mph while slowing down. The LCA are non adjustable and i grease them regularly.
Im gonna call the dealership that did my TSB and see what they say. I doubt theyll help but who knows
