raamaudio sound deadening?
anyone used this stuff... their prices are way cheaper than dynamat
http://www.raamaudio.com/index.php?o...hk=1&Itemid=60
Lets say I want to do my entire trunk space first, then the cabin at a later date.
How much material do I need to line the entire trunk bottom and sides including the spare tire well?
How much material do I need to line the entire cabin minus the headliner?
The point is I'd hate to get 5/6ths done with the trunk and be short material. It should be somewhat easy to deal with since I realize I can order too much knowing the extra can be used to start on the cabin anyway. But if I want to do both....how much would give me a say...5-7% extra so I have enough to fix 'mistakes' or where I messed up applying or something else unforseen?
Thanks
Andretti
Thanks
Andretti
I used FAT MAT 100 sq ft roll covered my trunk except for the lid , making custom trunk lid insert , still looking for carpet to match. Under the rear seat, behind the panels next to the rear seat, and the front doors . Used just under 50 sq ft. Still need to take out the front seats and console. estimate another 15 sq ft. hope this helps.
Andretti
I used this stuff on my last car...worked awesome actually. Mad cheap too. VW guys use it a lot apparently (been mentioned quite a few times on VWVortex). Very big difference in sound (I could have a conversation easily at 80mph where I never used to before), trunk stopped rattling, bass sounded 200% better than before.
http://www.cofair.com/roof.aspx
And you can usually find it at Home Depot so if you run out or want it quick, its easy to get.
