Go Back  MustangForums.com > Ford Mustang Tech > 2005-2014 Mustangs
Reload this Page >
PATS Thread - Program Your Own Keys & Other Useful PATS Info
Old 01-16-2010, 04:47 AM
Tylus
Tylus's Avatar
Default PATS Thread - Program Your Own Keys & Other Useful PATS Info
The following will be covered:
1. PATS System
2. Purchase a PATS key for "Cheap"
3. Programming a PATS Key
4. Programming a Remote/Fob/Clicker
5. Using a Fusion Key Instead
1. PATS System
PATS stands for "Passive Anti-Theft Security". It is Fords answer to car theft.
Inside each key, there is a little RFID chip. When properly programmed, your PCM reads and recognizes the RFID inside the key.
Without the proper RFID signal, the ignition system WILL NOT WORK. Motor won't even turn over...basically makes the vehicle one big paperweight. This makes it alot harder to steal a late-model Ford.
2. Purchasing a PATS Key
You have 2 options here.
2a) Buy one from the Dealership. Can run $50+ quite easily
2b) eBay! I have bought many many PATS keys from $5-10 shipped over the years. They are plentiful.
There are 2 ways to program a PATS key.
3a) You have 2 PATS keys that already are programmed = FREEBIE!
3b) You only have 1 PATS key programmed = Costly
Unfortunately, you must visit the Dealership, or a properly equipped Locksmith. They will have to connect a special tool to the PCM and perform the key programming for you. Roughly costs $40-50 (1/2 hour labor) for this service.
No requirements here.
Simply have all the clickers with you in the truck and go to town. Extremely easy. If you don't have a clicker, eBay is your friend as usual
So if you are like me, the key + clicker can be somewhat cumbersome.
the Ford Fusion key/clicker will work with 2007+ Stangs only. 2005/2006 cars utilize a different system and the clicker portion of the Fusion key just won't communicate.
I love the Fusion key I have for my Expy & Mustang.
To use program, follow the seperate programming instructions above for the key and clicker. You have to program each portion induvidually.
As for purchasing one...eBay!!! Notice a trend?
These keys are not quite as cheap as a normal PATS key however. But the going rate seems to be about $30 roughly. To me, highly worth it.
You go from this:
To this:
Hope this clears things up. If you have any questions, please ask.
Tylus is offline
Old 01-16-2010, 08:03 AM
157dB
Cut & Paste Expert
157dB's Avatar
157dB is offline
Old 01-16-2010, 05:08 PM
Tylus
Tylus's Avatar
thx DB. I had that in my favorites somewhere, but can't find it. properly saved this time now
Tylus is offline
lincolnshibuya
12-08-2015 04:37 PM
Dokilar
15
10-16-2015 08:13 PM
KingRando
10-02-2015 08:06 AM
RCS02v6
09-29-2015 01:46 PM
junior04
09-28-2015 10:53 AM
Quick Reply: PATS Thread - Program Your Own Keys & Other Useful PATS Info
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
