The Gas Tank Theory
In addition, the more airspace you allow in your tank the higher the amount of condensation that can form with temperature swings, resulting in water in the tank. This is another reason to try to keep the tank as full as reasonably possible especially in winter. Those of us in the northern areas are well aware of what a small slug of water in the fuel line will do when the temps are below freezing.
EPA mandates oxygenated fuel here... in our area, that's10% ethanol... we don't have to worry about water...
I fill up around 1/2 tank in all of my fuel injected cars... So far, haven't had to replace a pump, even with two of them at 200k miles... fingers crossed...
If so, you need to host the picture, I use imageshack, it is free and unlimited.
Then you go into User CP, signature, and go from there. Use the "picture" icon to enter the URL. (also the same thing if you just want to post a picture in a forum post, just hit the picture icon in the message box and post the URL).
Hey,
I have a theory that I would like to get people's opinion on.
I have often heard that you are not suppose to let the gas in your gastank drop below 1/4 tank because of fuel pump issues. Is this true?
If I wait until my gas tank light comes on to fill up, am I actually doing myself harm in the long run?
Fuel pump performance will degrade due to lack of proper cooling until they ultimately fail.
But consider this: Starting out with a full tank and filling it when you get to 1/2 vs letting it get low until the light comes on COSTS YOU NO MORE IN GAS OTHER THAN THAT INITIAL FILL-UP, period. You still drive xx # of miles, regardless whether you start with 2 gallons in the tank or 16. You STILL have to pay for what you use. If you think you're really saving anything by letting the tank get down to 2 or 3 gallons you need to think again.
In my older cars I hated to see the light come one because I was never sure exactly how much I had left in there.
Now, on my mustang it tells me exactly how far I have left to go until empty and as a result I have found myself riding around with the light on longer than I would have otherwise.
I disagree, I did a little beer math and I would argue that you will save money by letting the gas tank drop. Fueleconomy.gov says that extra weight causes you to lose fuel efficiency. Fuel is heavy. The average weight of a gallon of gas is 6.3lbs. My gas tank holds 16 gals (100.8 lbs) if I use the average of 2 percent of efficiency loss due to the added weight then I can determine the cost to carry it. Let's say a new fuel pump costs $300 to replace. If 2 percent efficiency equals 5 cents a gallon then I could pay for a new fuel pump after 120K miles which some are getting over 200K out of their cars. So let her get low, you'll save money and you'll be lighter... And faster. I know I'd be a lot faster if I lost a few pounds.
