Installing GTA's or any other muffler
I bought GTA's and will be installing them tomorrow. One of my buddy's who's going to help me asked if I had exhaust hanger pliers.
Any of you who did a muffler swap yourself, did you need exhaust hanger pliers or can it be done without having one?
No, I didn't need them when I installed my GTA's. You will need to remove the hangers from the car too, not just the mufflers from the hangers. There in one bolt on the drivers side that was a bit hard to access but it is not too bad. Easy job overall.
cool, thanks for the info guys. car only has 4k miles on it so I doubt anything is rusted in or anything like that. I've never done an exhaust on my own so I figured its better to check rather than start without tools i may need.
Please read TacoBill's HowTo in the stickies. His write-up has all the info you need to install your axlebacks and adjust the tips to fit correctly in the bumper cutouts. There should be absolutely NO bending or cutting required.
You're quite welcome. The amount of info in the forums can answer probably 95% of all questions. I always recommend that newbies read thru the forum and sub forums, especially the stickies, and absorb as much as they can. Besides the install info, it'll arm you well against unscrupulous shops.
The first time I did mufflers it took me about 2 hours. Which is funny b/c now I can do it in 30 min tops.
The reason is I didn't know what to expect and I also had a hard time with the hanger bolts. The stock mufflers take up so much space it's hard to get a wrench in there. Once I finally got them off, I noticed the stock mufflers had a notch where a small "****" thing was on the stock over-axle pipe. My aftermarket mufflers did not have this notch (none do) so I thought they would not go on all the way as-is so I went to go cut my own notch out. Turns out that was un-necessary. So that was wasted time there.
With small "mufflers," like boomtubes, loudmouths, etc you can remove the muffler without taking the hangers off. I did it once to bend one of my boomtube hangers so it would stop touching my bumper. I'd rather do that than mess with the mid-pipe.
