Sponsored by:
Sponsored by:
2010 Mustang HF Radio Frequency Interference
Old 01-24-2010, 05:26 PM
bobgn1
bobgn1's Avatar
Default 2010 Mustang HF Radio Frequency Interference
I have discovered a large amount of RF noise (~54 dbv) being generated by my 3 month old 2010 Mustang GT. A friend with a 2008 GT and has a very clean RF environment.
Both of us have installed HF Amateur Radio transceivers in our respective cars. Both of us have installed ferrites on the radio input for power, microphones, remote speakers, and remote control heads. In my car, this 54 db of noise exists from 7 MHz to 54MHz but is not present on the VHF and UHF bands (144 MHz or 440 MHz). I have not detected this on the Sirius (2.3 GHz), or the commercal FM channels (87-108 MHz) or the much lower commercial AM band (0.52-1.61 MHz).
The problem disappears when the radio antenna is removed so it appears to be something creating an RF field that is enveloping the antenna (trunk mounted very near the fixed AM/FM antenna) as opposed to being induced into the radio cables.
The problem is first seen when the ignition key is taken to the ON position but not the START position and before the engine is running.
Ford has had this problem before with their Explorer, and possibly other models. Based upon my friend's experience (same radio, same antenna, nearly identical mounting locations) there appears to be something new about the 2010 Mustang causing this problem.
Has anyone had similar RF problems on the new 2010 Mustang or 2010 Mustang GT? This problem would affect CB installation as well as HF Amateur Radio installations. How was it resolved?
Does anyone know if Ford has changed the Fuel pump (expected culprit), or how it is installed, on the 2010 Mustang from that of previous years?
bobgn1 is offline
Old 01-25-2010, 07:39 PM
Art161
Art161's Avatar
If you don't get an answer here, I suggest you email ARRL HQ (tis@arrl.org).
Even if they don't have an answer, they might have a contact at Ford who could help you.
73,
W6VV
Art161 is offline
Old 01-25-2010, 11:06 PM
10GTSTANG
10GTSTANG's Avatar
Possibly between the sirius ant cable and the radio ant cable a transmission line has been established? EMI field between the two cables?
10GTSTANG is offline
Old 01-25-2010, 11:49 PM
7up
7up's Avatar
In addition to what Art161 mentioned above, a forum member named FordEngineer is involved in the current design of the electronics (electrical/entertainment) systems.
You may want to ask/PM him about this issue. If he can't help, maybe he could point you to someone who can.
7up is offline
Loristic
08-17-2015 10:56 AM
iamgobono
08-16-2015 10:50 PM
daytooday
08-11-2015 09:22 AM
89blueslug
08-10-2015 07:20 AM
elraun
3.7L V6 Technical Discussions
08-09-2015 04:32 PM
Quick Reply: 2010 Mustang HF Radio Frequency Interference
