engine build parts list
Old 02-08-2010, 08:16 PM
graygt07
Default engine build parts list
need info from anyone who has replaced motors. I need a parts list to replace my short block.
1. short block
2. oem head gaskets
3. 8 bolt flywheel
4. fluids
what else do i need?
graygt07 is offline
Old 02-08-2010, 09:17 PM
BruceH
1. short block
2. oem head gaskets
3. 8 bolt flywheel
4. fluids
Head studs or bolts, front oil seal, oil slinger, fuel injector o-rings, water pump o-ring gasket, front cover seal/gasket, rtv, harmonic balancer bolt, oil filter adaper gasket, oil pan gasket, oil pickup tube o-ring, valve cover gasket/seal, intake gasket/o-rings, water crossover gasket/o-ring.
Most of the gaskets are closer to an o-ring in appearance, but they really aren't o-rings either.
Some of the seals/gaskets could be reused but I replaced them since I had it apart.
If you haven't already been to this link try it for an idea of what's involved and what parts will be needed.
http://iihs.net/fsm/?dir=159&viewfile=Engine.pdf
BruceH is offline
Calizic
08-28-2015 01:46 PM
Tyoung68
08-25-2015 04:31 AM
inyadreems
Mustangs For Sale
08-21-2015 09:10 AM
ohfarrell
08-19-2015 06:49 AM
djbigskrilla
08-11-2015 12:59 PM
Quick Reply: engine build parts list
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
