Fog help
Fog help
it is a little cold here and i want to use my heater but every time i do the windows fog soooo i have to turn the a/c on to defog it.
Is there anything that i can put on my windows to prevent this? If so what do yall use and does it work?
Thanks
Thanks
Take your climate control off 'recirculate'. When all you do is recirculate the interior air, the moisture from your breath and from snow/dampness on your clothing builds up the humidity inside, which then condenses on any cool surface. Glass being the target most easily noticed.
Use the setting that sends some air down to the vents near your feet and some to the defog vents.
A similar effect can occur in the summer with recirc + A/C under some conditions.
Norm
Norm
Diode Dynamics
28
05-26-2022 12:02 PM
