probably stupid, but lets hear it
ok my MM system fell apart for good and gone. well, until i get good cash, i gotta do something, dang wedding is running me and my gas tank dry. anyway, here is what i have left. just the xpipe. everything after the xpipe is done thanks to a taco bell speed bump. anyway, i plan run a 45* angle downpipe, (the kind of autozone) towards the ground and side basically right after the xpipe until i can afford my dream system. is this going to be bearable at all? heres a little paint picture i drew to maybe give an idea. thanks or no thanks depending on your answer. haha.
Maybe because I'm tired but I just had to wipe the tears from my eyes. I was even going to add a stick figure or two...
For one, it'll be pretty loud. Also, keep your windows open or you'll get sick from the fumes. Good luck trying to keep the cops from noticing. And condolences... I mean, congratulations... on the wedding.
If you have the cats it wouldn't be louder than a loudmouth setup. But instead of the rumble being behind u it would be underneath u. I say before you weld up the downturns, drive around with just the xpipe and see what you think before you go welding. I ran around on just the factory hpipe to see what it was like. Not bad. But with o/r h it was annoying so I put macs on. hope that helps.
same thing happened to me a while back, my whole exhaust somehow shifted back and disconnected, It was loud specially from a dead start, (have H and hiflow cats) needless to say my neighbors called the cops, I showed the cop what happened and he said just fix it cause that **** is too loud.
what a pos neighbor. anyway, i went through with it, and its not auctually after the x pipe, its closer to the rear axel. just a 45* dump right where the MM would go, so a couple feet behind. anyway, its hella drone yes, but the volume is quiter than i expected. just cant wait to pay for the o/r prochamber into cat back boomtubes. spendy setup tho. anyway i tried to take a healthy speed bump at an angel and it caught where the mm was and basicly planted itself on muff and as the car moved forward it bent all the hangers on the crap pypes system and pull the pipes right out and kinked it. hard to describe but not to imagine i guess. anyway, thats what happend and now is just dumped at an angle, halfway to ground and halfway to the rockers. loud yes, crazy, no. but as a corvette dude told me while grocery shoping, sounds like a dump truck man. haha. i will try to get a sound clip.
breaking
10-02-2015 01:27 PM
schecterplayer
09-23-2015 08:38 AM
