Missing a Gear...
What exactly happens when you hear that "sound" when you miss a gear? Is it actually the sound of gears grinding together?
I missed 2nd today and when I heard that noise (and felt it through the shift knob) I starting wondering what exactly happens when you miss a gear... |
Indeed, you have metal/metal grinding against each other. Do it enough, and you will have to replace gears/synchros in your transmission.
Don't do it, lol. :) |
No its not a habit of mine...LOL. Honestly this may have been the first time I did it in THIS car... :)
slow and sure better then fast and broken >.>
the clutch is still engaged and your 2nd gear was trying to jam in there... lol never good
slow is smooth, smooth is fast!
Originally Posted by Hoofprint
(Post 6836796)
I missed 2nd today and when I heard that noise (and felt it through the shift knob) I starting wondering what exactly happens when you miss a gear... http://auto.howstuffworks.com/transmission2.htm ...so it's not actually the "gears" grinding. Still sounds ugly, though. |
i gotta bring my car in, my second gear syncro seems to be off and it goes into the one gear quite rough.. any1 else experiencing this?
Originally Posted by livinloud98
(Post 6839819)
Since your description of "quite rough" can be quite open to interpretation, I'll ask if your issue goes away after, say, 5-10 minutes of driving (depending on how cold it is out your way)? Most people reported that once the car warmed, shifting was smooth again. Edit to say: And it mainly happened, as I recall, when shifting between 1st & 2nd gears. |
Originally Posted by 7up
(Post 6839871)
There was an issue brought up a couple/few months back where some folks were reporting temperature (cold) sensitive "notchy" shifting.
