How To Change Brake Pads?
Hey,
I'm installing my new Rotor Pro Drilled and Slotted Rotors and the Performance Brake Pads that they offer. I am using Taco Bills How To on the rotors, but I was looking for a How To on the pads. Is there one that ya'll can direct me towards?
Thanks,
Hunter
Thanks,
Hunter
You can "borrow" a kit from like Autozone or Advance for a fully refundable deposit that makes the job a lot easier. The fronts are pretty straight forward. The rears are a bit harder. The rear piston must be screwed in (clockwise) while pushing in on it. This can sometimes be a little tough, but doable. Make sure your master cylinder doesn't overflow.
Be sure to spray the BACK of the pads with a disc brake quiet product to avoid squeal.
Remove the cap, do one caliper at a time and you should be good. Once you have the NEW pads on then refill the master cylinder to within spec.
I had trouble finding a tool from Auto Zone.. I got the run around from those idiots and got sold two items, neither of which worked so they got returned and then asked if they had the proper tool for it (I had used one from my cousin once for a change). Those guys had no clue what was going on so I told them not to bother thinking and just go along with their day as usual.
I ended up using the tool that is used to remove the clamp disc for cutting blades on the smaller Dewalt grinders. It fit perfectly amazingly and is a handled tool so I could turn it. It was a bit of a bitch but rather it be a bitch than not be able to get it back on at all.
I use a vacuum brake bleeder to suck the fluid out of the master cylinder. Just don't hit the brake pedal until you refill it. I suck it dry, change the pads, suck it dry again then refill it with fresh fluid and if needed, bleed the brakes with nice clean fluid.
The "kit" you can borrow is a lot better than those little BS things (like that stupid cube thing) they sell. You can also buy a pretty decent kit from Harbor Freight then you have it.
