Vibration with Spydershaft
Quote: If you get a shaftmasters you may need to reinstall your stock pinion flange.
Yeah, that's what I figured. Should be easy though.
It's rare I go that fast, but it's nice to be able to if ever needed. Last year on the Hotrod Power Tour I had a corvette messing with me on the highway and I couldn't stay with him, because of the vibrations.
I wonder whether these vibrations are caused by an imbalance in the driveshaft itself or if there is a problem with the flange it came with or the install of the flange.
I assume you've tried the rotating the driveshaft fix for the problem? Some people have found that took care of things and it wouldn't require you to remove the flange.
Seen it before with the cut down Ranger shafts, most likely caused by excessive runout. You should take it to a driveshaft repair shop and have it checked out. I found a post that had before and after videos of one.
http://forums.themustangsource.com/s...25&postcount=1
ccdguy
09-19-2015 05:20 PM
