Sponsored by:
Sponsored by:
LOL. Quoted $1200 for gear change (parts + labor). What parts do I need?
Old 03-01-2010, 08:37 AM
MRGTX
MRGTX's Avatar
Default LOL. Quoted $1200 for gear change (parts + labor). What parts do I need?
The Ford Stealership where I bought my 2009 GT wants $1200 parts/labor for the gear change (from 3.31 to 3.73)...which, unless I'm mistaken, is way higher than what most of you guys seem to pay.
The labor wasn't too far out (about $350) but the remainder was for parts- ring and pinion, axle seals, fluid, etc.
What should you actually pay for parts on this job? Are they quoting me on parts that I don't need to replace? Obviously you'll need the gears and the fluid...but what else? The car has about 11k miles...
Thanks for any advice.
MRGTX is offline
Old 03-01-2010, 09:12 AM
dstang10
dstang10's Avatar
I was quoted $1100 to do mine at the dealership also...i'm still trying to find a place that has some experience dealing with gear changes. Seems like most pay around $600....
dstang10 is offline
Old 03-01-2010, 09:16 AM
Langor
Langor's Avatar
Check out American Muscle dot com for prices.
http://www.americanmuscle.com/05-07-mustang-gears.html
Remember that your speedometer will be off after you change your gear ratio. So make sure you have them flash the computer with the new gear size or buy a tuner.
Here is a tech guide that goes over what to consider.
http://www.americanmuscle.com/mustan...ial-gears.html
Here is what I would get...
http://www.americanmuscle.com/xcal2-...r-oil-kit.html
I am headed to work, maybe someone else here will give you more detailed info, hope this helps though.
Langor is offline
Old 03-01-2010, 09:24 AM
MRGTX
MRGTX's Avatar
Thumbs up
Thanks so much for the links!!
I'm reading up now.
I have an SCT tuner already fortunately.
MRGTX is offline
Old 03-01-2010, 09:30 AM
MRGTX
MRGTX's Avatar
From everything I have read about gears on this fourm, it seems like a no-brainer to go with the FRPP gears rather than those offered by Motive but in the FAQ link on American Muscle, they suggest this installation kit made by Motive:
http://www.americanmuscle.com/moinkit8re.html
Any reason why this wouldn't be compatible with FRPP gears? I can't imagine that would be incompatible but if anyone knows something I don't...
Thanks again.
MRGTX is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: LOL. Quoted $1200 for gear change (parts + labor). What parts do I need?
