Where would a gas smell be coming from
i had the exact problem. They were walking around in circles for almost 2 months and my car was tied up in their shop for 3 + weeks.
Here is the oasis report
ZVFT82HX55126943 C/ZF F C/BJ * C/B CL C/SK C/HZ 02-DEC-2004 30-APR-2005
4A7069 CAN 32 1D05 031004 3L3Z 6584 EA L65 07 14740
AWS Claim Key: 9029674 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: B7232 - * Name: COASTAL FORD SALES LTD Ph: 604-2946525 St:BC
Ctry Cd: CAN Reg Cd: NA Repr Date:23-NOV-2007 Doc #:304379B
Cust Comments: GORDEN LAU CHECK AND ADVISE CAUSE OF GAS OR EXHAUST SMELL
Tech Comments: RECHECKED CAUSE OF CONCERN FOUND RH SIDE VALVE COVER GASKET
LEAKING. P/O RH VALVE COVER GASKET NOV 26,07 RE AND RE RIGHT SIDE VALVE
COVER AND REPLACE GASKET. FINAL ROADTEST DONE, COULD NOT SMELL VAPOURS FROM
ENGINE AFTER VEHICLE FULLY WARM.
1ZVFT82HX55126943 C/ZF F C/BJ * C/B CL C/SK C/HZ 02-DEC-2004 30-APR-2005
4A7069 CAN 32 1D05 030001 5C3Z 6582 HA D50 42 14740
AWS Claim Key: 9021517 Trx Code: E84 Labor Hrs: 4.5
Ctry Cd: CAN Reg Cd: NA Repr Date:23-NOV-2007 Doc #:304379A
Cust Comments: CHECK AND ADVISE CAUSE OF GAS OR EXHAUST SMELL. LET IDLE FOR
A TIME SMELLS EXCESSIVELY FROM OUTSIDE AND VENTS ON FRESH AIR SMELLS LIKE
GAS OIL FUMES
Tech Comments: DIAG. D50 42 CHECKED VEHICLE FOR CRANK CASE VAPOR SMELL
COMING FROM ENGINE COULD NOT PIN POINT EXACT CAUSE OF ODOR,DID NOTE THAT
SMELL WAS MORE PRONOUNCED FROM REAR OF DRIVERS SIDE OF ENGINE. PCV IS A PART
OF THE DRIVERS VALVE COVER SOUGHT HELP FROM HOTLINE AND PREFORMED THE
FOLLOWING REPAIRS. REPLACE DRIVERS SIDE VALVE COVER AND GASKET RE AND RE ALL
SPEARK PLUGS AND RETORQUED THEM TO ENSURE
4A7069 CAN 33 1D05 031004 3L3Z 6584 EA L65 D4 15201
AWS Claim Key: 9208158 Trx Code: E84 Labor Hrs: 1.6
Ctry Cd: CAN Reg Cd: NA Repr Date:19-DEC-2007 Doc #:305596A
Cust Comments: REPAIR FUEL OIL SMELL IN VEH WHEN HEATER SET TO DEFROST
Tech Comments: CHECK FOR CONCERNS CRANKCASE VAPOUR SMELL FROM SIDE OF
ENGINE.WILL REPLACE PASSENGER VALVE COVER AS PER HOTLINE RECOMMENDATION.P O
WILL ARRIVE NEXT WEEL. DID OIL DYELIGHT TEST WITH BLACK LITE NEEDS VALVE
COVER GASKET,RR VALVE COVER AS PER HOT LINE TRY NOW. 6584AR 1.1 6007D .5 LAB
D1 RERUN ALL VAPOUR SMELL RECTIFIED. DDDR1 PARTS DEFECT REPEAT REPAIR REF RO
304379A
4A7069 CAN 33 1A01 030002 6L3Z 6049 C D50 42 15546
AWS Claim Key: 9533134 Trx Code: E84 Labor Hrs: 13.8
Ctry Cd: CAN Reg Cd: NA Repr Date:08-JAN-2008 Doc #:306257A
Cust Comments: GORDEN LAU CORRECT ODOR IN CAB. SEE HISTORY OF ODOR SMELL
Tech Comments: TECH 39 REPORT 3RD TIME STILL SMELLING CRANKCASE VAPOUR FROM
ENGINE.THERE IS NO TSB OR KNOWN CONCERNS FOR THIS SYMPTOMS. FORD TOLD US TO
REPLACE BOTH VALVE COVERS THEN START LOOKING AT THE INTAKE. WILL REPLACE
INTAKE SEALS & RETRY. REMOVED ROCKER COVER & INT MANIFOLD. WE HAD THE
INTENTION OF REPLACING ROCKER COVER GSK & GROMMETS AS WELL AS INTAKE
MANIFOLD. PRIOR TO INSTALLING MANIFOLD, NOTICED SPA
4A7069 CAN 33 1A01 030102 * 6049 * D50 42 15546
AWS Claim Key: 9526703 Trx Code: Z16 Labor Hrs: 0
Ctry Cd: CAN Reg Cd: NA Repr Date:08-JAN-2008 Doc #:306257D
Cust Comments: GORDEN LAU CUDL REF #1693970947 CONCERNS OF SMELL/ODOR IN
CAB.
Tech Comments: CUSTOMER REQUESTED RENTAL VEHICLE FOR PRO LONG REPAIR DUE TO
SMELL/ODOR IN CAB. VEHICLE IS NON DRIVEABLE DUE TO CRANKCASE VAPOUR ENTERING
INTO CAB. TOTAL 20 DAYS RENTAL FROM ENTERPRISE RENT A CAR @ $35.00 P/DAY.
APPROVED FOR 15 DAYS DUE TO COMPLICATION DURING REPAIRS, CYLINDER HEAD WAS
DIFFERENT FROM CATALOG, CYL HEAD HAD TO BE REMOVED AGAIN AND THE BARE HEAD
HAD TO BE REFITTED WITH OLD BLOCK VALV
4A7069 CAN 33 1A01 030100 5R3Z 6049 BA D50 42 15546
AWS Claim Key: 9658969 Trx Code: E84 Labor Hrs: 4.6
Ctry Cd: CAN Reg Cd: NA Repr Date:08-JAN-2008 Doc #:306257E
Cust Comments: GORDON LAU CONTINUATION FROM LINE A
Tech Comments: TO FOC ASSESSOR PLEASE REVIEW WITH MATT @ WHL. THIS LINE IS
FOR PARTS WARRANTY........ RECHECKED PART # INCLUDING STAMPINGS FROM HEAD,
PARTS CATALOGS & NUMBERS ON PACKAGING AS WELL HAD HOTLINE CHECKED INTO PARTS
PACKAGING WRONG. CONTACTED HOTLINE & DETERMINED THAT THE CYL HEAD WAS INFACT
PACKAGED WRONG. PHYSICALLY EXTERNAL HEADS ARE IDENTICAL. .CALL HOTLINE ON
WHAT TO DO NEXT. CALL MATT @ WARRAN
**edit**
Just realized the report didnt state what went wrong
My cylinder head ( forgot if it was right or left ) had a manufacturing defect in it. Somehow there was extra metal in the casting that lead to crankcase fues forcing their way past the valve covers....i think that was how the shop foreman explained it to me
GAS OIL FUMES
304379A
CAB.
**edit**
[Mustangmaster]
I looked under where the fuel filter is. But, didn't take any covers off and didn't see anything. Do I have to take any covers off to see the possible leak there? Or should I just see it by looking under there?
I can tell ya from my experience, getting the shroud off was kind of a b!tch. It might be easier to just remove one side just to be able to check for a leak.
