Factory HID headlight change
When I ordered my car the factory HIDs were not yet an available option. I like the way the Roush Stage 3 looks with the HIDs. Does anyone know if you can swap the standard headlight out for the HID lights easily. Does it require a different harness or just the addition of the factory ballast set-up??
well if u want the ford factory HID's u need to be ready to shell out some good $$$$, retail price on those lights go for around $800 per/headlight and the only change u would have to do is replace the pigtail that plugs into the headlight which run around $70 each one.
Hey Wil... Do you mean adding aftermarket HIDs? If so, it's very easy as long as you order a good kit. I recommend retro-solutions. It basically comes with ballasts, wiring harnesses, and bulbs..... The bulbs fit right into the factory bulb location. If you mean factory HIDs, I have no clue
I'm keeping my options open and retro-solutions will be my first choice if I don't do the Factory HIDs
yea i know what u mean, well u might have some luck looking on ebey from time to time along with craigs list and the web site car-parts.com also has plenty of parts on there, u might get a better deal looking around but theres no substitute for new stuff like that, well good luck on the project
