Both Stangs out of ~4 month storage; odd temporary issue
Both my '07 GT and the g/f's '06 V6 came out of storage this past Saturday. Both fired up just fine. I'm scratching my head, however, on the following items. Mind you, BOTH were on battery tenders with the batteries left connected and were both powered from the same outlet:
- My clock on the radio was off by over 3 hours and when I turned the radio on, it was on the AM band; NOT how I left it. The presets for my sat channels were still good. The g/f's was fine. Even if we had lost power to the tenders for a period, the cars battery would have picked up the load. And had it been an extended power loss and the battery had died (only to be recharged by the tender), wouldn't I have lost my presets plus other electrical changes?
- BOTH cars, upon the first roughly dozen applications of the brakes, acted as if the rotors were BADLY warped. The wheel shimmy during braking diminished with each application until it was gone on both cars but I have NO idea why sitting in storage would have caused this.
The brake pads probably deposited some sweat on the disk where they were touching creating light surface rust/scum. Quite normal. Also it's possible your tires were slightly flatted from standing which can manifest itself in brake shimmy. Unless you leave them standing for years, those flats run out after a few miles
as for the radio, the sat radio presets are stored in the sat radio tuner itself i think. this is normally a additional piece of external hardware. but it does seem that the actual head unit lost power completely at one point. Honestly i wouldnt worry to much as long as it doesnt happen again.
agree with this on both acounts.
I'll check the FM presets again (i was preoccupied when I checked them and, to be honest, I always listen to sat). THAT should tell me that the HU lost power.
As far as the brakes, marcus' explanation makes sense. Thx.
I keep a piece of paper in the console with my menu settings (including radio presets) written on it. But sometimes I don't update it when I make changes. My bad.
zanemoseley
09-06-2015 12:58 PM
