Saleen SC noise
Saleen SC noise
My saleen sc sounds like a bad a/c compressor and i can feel a vib from it the sc only has about 800 miles on it, has any one had this issue before.
thanks
thanks
What does it sound like? I had a constant low knocking noise on my Saleen and at first was told that the superchargers are just loud like that. Then I was told it was the fuel injectors. And then my motor blew up a few days ago at 6800 miles lol.
If you can, be a bit more descriptive and we'll see if we can get to the bottom of this.
After your ordeal, the OP should park his car right away and figure this schit out first.
siggyfreud,
It sounds and feels just like a bad a/c compressor with a vib also. It does not sound like a knock but you never know the guy at saleen said its normal but i dont think so.Do the screws rotate on bearings?? maybe I have a bad bearing.
thanks,
thanks,
If you have a vibration, it's bad news.
Most likely, too much stress on the crank...
I'm no expert with blown cars but those are bad symptoms.
Have the car looked at by an engine builder or someone familiar with hi-po stuff.
Screw Saleen, all you'll hear is the same old BS...
Good luck.
Good luck.
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
Ghost_Conscience
09-23-2015 02:17 PM
