Electric fans for Whipple intercooler?
#21
160 is way too hot to wait for the fans to come on. Mine run with the key in the "on" position.
I'd do water/meth injection in a minute if I could find an adapter. I know BBR has the plate for the Ken Bell which is nice as long as you have the 1" clearance under the hood. You could go with aftermarket motor mounts which would lower the motor about a 1/2" if your close.
#22
#23
#24
at cruise with it being about 80-90 out right now and no fans I'm around 120-130 degrees on the intake temps. I agree that the fans not coming on till 150 is a little too high. if you could set them at like 100 degrees then it would be cool. if I add fans I'll just have them on 100% of the time. you can never have too cold of intake temps
#26
Derale 9" fans x 2
Derale adjustable fan control thermostat. Temp range is 150-240; not 220 like I thought.
You might need some 16ga wires (depends on thermostat mounting location) to extend the fan wires to the thermostat. I had to extend because I mounted the thermostat on the strut tower.
#27
http://www.blowbyracing.com/bbr2628scmep.html
On FI applications the meth/water injection must take place after the intake air is compressed to have any benefit. This requires drilling and tapping the intake or a plate sandwiched between the blower and intake manifold. If you place the plate at the TB then the meth/water is being heated through compression so any results are nominal at best. I am not aware of any sandwich plate for the Whipple, only the one above fro Ken Bell.
#28
I've heard of people spraying pre-blower. Why wouldn't that be effective? Cooling comes from evaporating the water/meth as it takes the addition of heat for this process to occur (hence heat is sucked from intake air). I know that some people are against pre-blower applications due to the possibility of the methanol corroding the surface coating inside the blower.
#29
http://www.kennedysdynotune.com/wate...20with%20Water
I am not convinced with this dyno run since the HP is low and the boost is relatively low as well.
