saleen boost gauges bounces
I have a 2006 roush with a saleen S/C, I have the saleen boost gauge pod and the boost gauge bounces around under boost. The guys at ford are saying this is pretty common... so what is the fix for this?? OR are there any gauges that are a direct replacement that will fit in the Saleen gauge pods?
Also, if I take the dash pod off and use a pillar setup are there holes in the dash....I am guessing there will be.
Thanks
Chris
Thanks
Chris
my boost gauge is rock steady until higher rpms and then it gets a bouncy. not sure if it's because of where it's tapped into the vacuum/boost hoses or if it's the gauge itself. I'm tapped in right before the bypass valve and it's an Autometer gauge.
jwog666
12-27-2021 08:09 PM
Galactic
04-29-2019 02:56 PM
mungodrums
09-28-2015 10:54 PM
