Sponsored by:
Sponsored by:
Hurst Questions Search Didn't Answer ;)
Old 04-21-2010, 09:20 PM
iROK24/7
iROK24/7's Avatar
Yes you are correct. See pics.
Disconnect the linkage below the shifter and slip the hose over the vertical section of linkage hanging down from the shifter under the ball/socket (it just fits after you remove the bushings & compress the hose). Replace the bushings after the hose is in place & reconnect the linkage. The hose will end up in contact with the underside of the ball/socket at its top and the horizontal section of shifter linkage at the bottom. The slight compression of the hose maintains a pressure on the mechanism which dampens/kills the vibrations causing the ball to rattle. The shifter will feel pleasantly tighter & the action going from gear to gear will feel very smooth & positive.
It will all become clear when you get under the car!
Good luck... it really works!
iROK24/7 is offline
Tivo304
08-28-2023 12:19 PM
2007CalSpec
12-13-2020 11:42 AM
carid
07-08-2016 09:55 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Hurst Questions Search Didn't Answer ;)
