Loud clunking in the rear? Ford can't find it... Help!
#21
The factory torqued all the bolts in the back of the car and it still does it, now there saying it cold be a shock that they just replaced or the shock tower mounting point. Ill find out tomorrow if they did anything and ill let you know.
#22
The Ford place should know this and follow the workshop manual and
replace the hardware as it is not to be reused and retorqued but thrown
away and replaced with new one-time-use fastners whenever removed.
Sounds like they are going to cause you lots of problems down
the road when all the rear interior they removed starts to drive
you crazy with new rattles and squeeks....
#23
Well I went to look at the car and all they really took out was the bottom of the back seats which just clips in and they took the top of the back seats and folded them down.
Ill ask them about why they did not replace the bolts. Thanks.
#24
So Ford told him yesterday that they were giving up on the car because they couldn't find it and that he should just come pick it up. He mentioned the single use bolts to which the service manager replied "well i guess you'll need to buy some bolts"
I'm completely dumbfounded at the lack of customer service, skill, and downright "we don't give a f*ck" attitude this dealer has. What's worse is that dealer is the "sponsor" of the local Mustang club we're both in.
W...T...F...?
W...T...F...?
#26
I already know what his problem is.....
The OEM UCA mount has a 16MM hole, but the OEM UCA (aftermarket ones also) only have a 14MM hole and Ford used a 14MM bolt to mount it to the OEM mount. This leaves 2MM of slop that clunks.
Here is the fix!
UCA Stepped Spacers
It amazes me how a call to Ford corporate wouldn't have brought up this fix.
Here is the fix!
UCA Stepped Spacers
#27
I've been in a 2007 that didn't have that clunk coming from the rear. Not saying that the upper and mount aren't producing the noise but it seems a little strange that some cars would do this while others do not - and they are both using OEM hardware back there.
#29
Mine has clunked when going into 2nd frequently since I bought it. After a axle-exchange driveshaft went in the issue is still there. Had zero effect on that. I doubt your car is going to break on you because of it.
The other clunk I'm getting out of the rear is when going over bumps and not upon acceleration. It's easy to reproduce. Go up a driveway, over railroad tracks, or a washboard part of the road. Chuckles like a ****. My lowers are in there fine and the rest back there is stock.
I intend to investigate this myself over the weekend. If I figure it out I'll post back here. I've been told it's the upper/mount, which it might be, but I want to confirm.
#30
The fix cost me 19.00 shipped.
