Cam installation question.
#21
About the install...
There is some pressure, but I don't believe there is more than 18lbs on them. If that's a worry, use a torque wrench when you do it, if you are pushing on them more than that then move to the next one. but I promise you it isn't that much. I remember doing it with my 1/4" socket wrech and it wasn't very hard.
#22
I've seen pictures of cams being installed at well known shops with all tools presents to include power tools, and the only tool missing is the spring tool and no sign of followers being removed. I'm comfortable doing it that way... But it's like everything we do... To each his own ya know...
Did you get my PM BTW???
#25
Detroit Rocker
Hey some of the folks chimed in and wanted to know more info on this Cam.
1 Sorry I could be no help on the install I had Dave at Brenspeed do the install.
#1 thing I will say is let the car warm up and get past the start up idle and then it drives and shifts fine not to say it has problems.
The power gains are great and in person the idle is over the top.
At low RPM's you will feel that the clutch to shifter relation has changed a little bit but is still 100% better than the original Thumper profile and what I mean is you have to learn the Thumper and at times slip the clutch in and out while in heavy traffic.My over all review is these Cams give the N/A owners what we have been looking for I will say the gear is a must I went with the 3:73 if you race or want to race the 4:10 is the way to go for the straight line folks.
#27
#29
better yes, fixed... not so sure. It actualy seemed pretty good driving around today. Think the temp effects them a bit too. It was 70 today though, and was fun to drive. Do you know what year heads your running? the 08+ has more plug options as well.
