05+ In-dash stereo advice?
I currently have a Shaker500 setup going on, but I want to install a 7in. touch screen. Is there anything I need to do to bypass the factory amp? and do I need to buy an install kit that the double-din fits into? Also if anyone has any recommendations towards brands? Dont really want to spend over $500 and i dont need NAV because i have a garmin. Thanks!
FWIW I love the newer JVC navi units, had one in my last car and they're awesome! plus you can play DVD's and enter navi addresses while moving. most newer units detect the movement through the GPS and own you the JVC's just warn you at every startup, I like that over not being able to enter addresses unless I"m at a stop
There are some really good threads on this subject. You can get the wiring harness adapters and trim kit at your local stereo store. Basically the shaker 500 uses the head to power the small upper range speakers. It has a separate amp for the door mounted sub woofers. With the correct harnesses you can provide low level audio to the existing sub amp or you could power them with the addition of a new amp. JUst depends how much bass you want.
here you go, all the info you can need on it, will be found here. Great site for almost all information you can need on most anything:
http://tinyurl.com/285sotx
