The Undead Saleen - Rebuild Started
#101
Nice motor- I look at this motor and all your hard work going into your car. I view this as a great upgrade. You make me and many of the Saleen guys proud. You could have went the cheap way out and just dropped a used motor in your car, but you’re doing it the Saleen way, turning your negative into a positive and coming out with a better car in the end, nice job. You should also post the photos of the bad motor on a Saleen web site. Let them see your story ….
Thanx-Muzzy 04 S281SC Convertible #355
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Ported and Polished SC by PSE
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
Chicane ss braded IC lines
Carbon fiber dash kit and shift ****
1 bottle of water wetter (haha)
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
#106
Part 3 - The Cover Up!
Here is the timing cover on with all the pulleys and water pump. Almost everything gets torqued to 18 ft.lbs, and if you're like me, you own a torque wrench that starts at 20ft.lbs so be sure and have your neighbor handy!
Part 4 - The F Bomb
Whats an engine project without some kind of screw up? I'll tell ya, it's a fantasy. Here is where I went just a LITTLE too far with a temp sensor.
And here is how I got it out. I just tapped the extractor in since the part that got stuck is tapered, and then used a crescent to pull it out. Well, actually my dad pulled it out since my hands were full with the camera and a Sprite.
Part 5 - We got the red on dead on . . . well almost.
So the valve covers went on and I must say my GF did a good job picking the color. It's pretty freaking close. Don't forget to lay a little silicone down where the timing cover, heads, and valve cover meet. There IS a torque spec and pattern to these things, so beware of that.
All for now. Should have more Thursday night or Friday. Provided I can get that sensor, should still be on track for firing it up this weekend!
Part 4 - The F Bomb
#109
It's okay. After dropping $12 a pop on two little o-rings, I probably won't be phased by whatever it costs.
After it's all done and I know I did it right I'm gonna rewrite this thing with more technical info so it will be more complete. We should get all of us who are doing or have done a build and create a Performance 4.6 rebuild Wiki or something.
